steer encoder ecr2
I AM GOING TO CHANGE STEER ENCODER FOR THE FIRST TIME ON A SP3500. THE HANDSET I USED ON THE OLDER MODELS DOESN'T PLUG IN CAN ANY ONE WALK ME THROUGH THE ECR2 ALIGNMENT PROCEDURE. I HAVE A SERVICE MANUEL BUT IT DOESN'T GIVE ME HOW TO CENTER ENCODER
  • Posted 5 Feb 2020 00:51
  • By MRLIFTOFNY
  • joined 11 Sep'08 - 51 messages
EMAIL ; MRLIFTOFNY@AOL.COM
Loosen the 2 screws and turn it
  • Posted 11 Feb 2020 08:19
  • By Randy_Keilback
  • joined 10 Feb'20 - 5 messages
whats the trick to moving the encoder at the front of the lift and seeing the 0 at the dash do you need 2 people
thanks ray
  • Posted 11 Feb 2020 07:20
  • By MRLIFTOFNY
Power up truck and wait until it times out. Lift drive unit enough to physically turn the drive unit and line up the 2 lines etched in the drive unit and bearing pivot. Find ECR2 counts through Access1. Physically turn the encoder to zero. Drop the truck and calibrate steering.
  • Posted 10 Feb 2020 14:37
  • By Randy_Keilback
