starts low idle then dies impco100
checked and found no fuel pressure changed lockoff and vaporizer
while i had air cleaner off i tuned it up ( cap rotor wires plugs module )
fired up ran great was checking temp and for leaks , then died started doing same thing started idle low dies , changed carb still same , drained fuel system truck will run great with gas rag over carb truck has 155 compression on all four
  • Posted 7 Aug 2019 11:32
  • By owen_r
  • joined 19 Jul'12 - 12 messages
  • Kentucky, United States
O
I missed that you changed the carb. If you have a vacuum gauge, check the vacuum while cranking. If you get large pulses this can cause the system to not prime properly. some times a valve adjustment will help
  • Posted 8 Aug 2019 07:06
  • By BREWSKI
  • joined 10 Jan'12 - 1,698 messages
Which carb/mixer does it have on it? If it is a CA100 check the diaphragm.
  • Posted 8 Aug 2019 07:03
  • By BREWSKI
It has a new lockoff that's the only filter and I have fuel through the lockoff to the vaperizer
  • Posted 8 Aug 2019 01:04
  • By owen_r
O
Check the in line fuel filter. Also check your LP coupler.
  • Posted 7 Aug 2019 22:16
  • By BREWSKI
Airman ENCL045
Wellwit WMF1000
Shenzhen, Guangdong, China
USD50,000
September 9-11, 2026 - Hanoie, Vietnam
September 16-17, 2026 - London, United Kingdom
Alogotransiphobia is the fear of being caught on public transport without a book to read.
Yale hosts dealer showcase in Germany Mörfelden-Walldorf, Germany
UK names its first Logistics Minister Leicestershire, United Kingdom
edition #1294 - 13 August 2026
In this week’s Forkliftaction News, we report on Jungheinrich’s H1 financial results and the reasons it has adjusted down its EBIT forecast for the year... Continue reading
