starts but runs rough
I have a Cat GC25K ser. AT82C-03197. Just replaced the engine. Had trouble starting engine and had to clean out the fuel system. It seems weird but I removed the fuel line to the mixer and when the engine would start I would put the fuel line back on. Runs but it dies when you accelerate. Adjusted the throttle pos. until it would stay running. Still dies if you step on it but not if you gradually step it up. The other problem is it will not go into gear. I have power at solenoid but no direction.
Could this be a programming problem? Do I need to call the dealer to program it? Does the throttle pos. have anything to do with the trans.? The engine seems to run better the longer I leave it running.Please help. Thanks, Jim
  • Posted 24 Oct 2012 09:45
  • By jim_v
  • joined 26 Aug'08 - 61 messages
  • Michigan, United States
First off the only indicator for any problem that occurs on this truck is the MIL light on the dash, if any problem comes up in the system this MIL light will light up and stay on as long as the problem exists. This is a Carb Tier 1 system on this truck so there is no ECM so to speak. It is refered to in the manual as an ECS (Engine Control System). This is a 4G63/4G64 engine setup. Being a GC25K most likely is 4G64, you can verify this by looking on the right side of the engine on the block, there is a flat (machined)place that has the engine model stamped on it.
There are 2 tools available to use to adjust this system, a GSM handset and also the SG15 laptop program. The manual references the laptop program only, i have no setup information relating to the handset interface.
The accelerator pedal can be set using this program, if you want to try and do it by hand good luck, you may get lucky and get it set.
IF there is a timing spocket mounted on the front pulley check the wiring and make sure the harness is not damaged and all connections are good. Generally if this component does not work or the harness is damaged the engine will either not run at all. Might be worth checking though.
Anywho, if you just replaced the motor i would check the mixer and make sure its clean, the diaphram is not damaged. And one other thing is there is a setting that has to be set using the adjustment screw on the mixer, it is hidden behind a plug and is used to set the dwell on the fuel system. If this is not correct the engine will not run correctly. There is a high possiblilty that it was setup to run with the old engine and has been adjusted over time and will need to be reset back to factory setting since this is a new engine.
Now some of the stuff MEngr said about checking vacum lines, make sure they are connected correctly. Also if it has a new throttle box it will have to be relearned to the pedal position sensor. If it is the old one then nothing needs to be done as long as no-one disturbed the pedal sensor setting.
As for the spark plugs? use the ones cat suggests , the current part number for these plugs is 1038083 for the LP engine.
I would concentrate on the pedal sensor setting and the mixer dwell setting, you might find this is where your problem is.
just some things to ponder on while scratching your head...
  • Posted 24 Oct 2012 22:59
Jim;
Have you the handset for this particular truck that you can monitor the the HEGO (Heated Exhaust Gas Oxygen) sensor?
Are there any DTC (Diagnostic Trouble Codes) showing on the Instrument Dash? Have you taught in the throttle position and the accelerator position sensor? Does the engine replacement have the speed sprocket? Haye you reinstalled all of the fuel system vaccumn lines between the LPR (Low Pressure Regulato) and the mixer? With the handset you should be able to the inputs of the sensor to the ECM (Engine Control Module) and the Module outputs to the actuators. Important item to note spark plugs need to be LPG (R46TS).
  • Posted 24 Oct 2012 13:33
  • By MEngr
  • Missouri, United States
edition #1239 - 17 July 2025
As part of Forkliftaction’s 25th anniversary celebrations, we have dug into the archive and, over the next year, will be highlighting a carefully curated selection of historical stories we have published over this time... Continue reading
The origin of "love" as the score zero in tennis is debated, but two main theories prevail. One suggests it's derived from the French word "l'oeuf" (egg) which resembles the shape of the number zero. The other proposes it's related to the Dutch word "lof" meaning "honour" as players might be playing for honour when scoreless.
Yale Lift Truck Technologies
Mike Barker Mike Barker
President and CEO Swisslog Americas, Swisslog
Vice president, Newgentech Material Handling India
Sales representative, Alabama and Panama City, Thompson Lift Truck
Chief marketing officer, Bobcat Company
