Starts and runs then dies
Truck starts and runs fine everything works after about 30 seconds it dies and horn goes off. Always starts back up and runs for same amount of time and then same thing. It's not a fuel problem, it's taking power away from coil, If you hot wire coil it will stay running but horn goes off after 30 seconds. Anyone have this symptom?
  • Posted 10 Jun 2022 01:34
  • By Mitch_Egan
  • joined 7 Jan'21 - 6 messages
Thanks Scott, there is a black module under there that I believe is an engine shutdown module, but don't know how to check to see if it is bad and it's $1000 to replace, I also don't have a wiring diagram to see about troubleshooting
  • Posted 13 Jun 2022 23:07
  • By Mitch_Egan
What l remember is this truck is a little old by today's standards some were built with a powertrain protection system and some were put on aftermarket there was a small black box under the dash covers the wiring went to the main components that cause the engine to fail if something went wrong like low oil pressure or no oil or water problem like overheating it would shut down the spark and the horn would blow. Check to make sure that all your fluids are good and you do not have low oil pressure. if everything is good there could be a problem in the system. Might be able to disable it but l do not have wiring diagram..
  • Posted 11 Jun 2022 11:48
  • By Scott_
  • joined 16 May'21 - 342 messages
Scott
Cameron Paxton Cameron Paxton
President and chief executive officer, Toyota Material Handling Australia (TMHA)
President, Doosan Bobcat North America
Chairman of the board of directors, Manitou Group
Sales manager for the UK & Ireland, BSL Battery
Ncn 85TH
Ncn 85TH 2014
Hangcha CBD15
China
USD1,600
November 3-4 2026 - Houston, United States
edition #1289 - 9 July 2026
In this week’s Forkliftaction News , we continue our coverage of CeMAT Australia with a report on how the lack of local after-sales support and service is hurting new foreign entrants into the Australian market... Continue reading
