Starting Problem
We have a weird starting problem. Sometimes will start. We have spark, timing is on and good compression. If we spray starting fluid or carb cleaner in carb, it will not start. But if we blow air down the carb while cranking, it will start right up and run as long as there is some throttle applied, but will dies when throttle is released and will not start until air is blown in carb again. If anyone has any ideas or suggestion, please let me know. Thanks
  • Posted 15 Jan 2009 05:34
  • By communityauto
  • joined 15 Jan'09 - 2 messages
That is a test I found seems to work OK What type of regulator(propane) is it. (aisin) or impco?
  • Posted 24 Oct 2009 07:12
  • By rich_k
  • joined 30 Oct'07 - 108 messages
Hi Rich,
I've owned my fork lift for less than 24 hrs and that's exactly what I did when it did not start. Thought it was kinda neat to see your post.
Being new to Toyota LPG fork lifts...is this a know regulator problem as it seems to be intermittent. Also..who is a trusted online parts supplier? Thanks for your time and any help you can forward.
Don
  • Posted 23 Oct 2009 12:50
  • By don_t
  • joined 23 Oct'09 - 1 message
  • Michigan, United States
Pull propane line off at carb and hold half inch from port and if it starts you have a regulator problem
  • Posted 4 Mar 2009 07:09
  • By rich_k
Did you see if the slow path on the regulator is working? It sounds like the regulator may need some attention. Have you drained the oil out of the regulator?
  • Posted 30 Jan 2009 11:54
  • By rogeriwt
We pulled the carb off and the intake is clear and I even ran a boriscope in the runners and they look clear also.
  • Posted 16 Jan 2009 05:28
  • By communityauto
Check the inlet manifold for blockage or restriction.
  • Posted 15 Jan 2009 08:03
  • By danny_k
Yale Lift Truck Technologies
