Check for voltage drop between starter and keyswitch, you are not allowed more than.2 of voltage drop. A lot of these units were not getting enough voltage to crank over, also a relay added to crank circuit would correct your problem and must be wired properly as well as fused.
Is the ground cable hooked up on the top starter bolt? I suppose you have checked the neutral start switch, we used to have a lot of problems with the main harness plug in the dash on the 5 series when I worked for the dealer. Just some thoughts
