SPEED SETTING
Does anyone know how to change the speed from low to high or visa versa? On a TCM with the same engine (K25), we just have a resistor which is plugged into the harness. Is it the same for a Cat or is this done only thru the computer?
  • Posted 31 Oct 2012 05:16
  • By Rodey
  • joined 16 Oct'12 - 21 messages
  • Michigan, United States
if you want to do it right and have both the engine and transmission sync'd then the ecm is the only way to do it on a cat c and p series.
depending on when this cat was mfg'd depends on wether you can do it with the laptop or not, the tier1 and early tier2 's the ecm had to be sent back to the factory and reprogrammed.
  • Posted 31 Oct 2012 06:53
  • Modified 31 Oct 2012 06:54 by poster
Crown WP302020
Taylor T520S
