speed issue
Hello,
When driving on Low speed (with fully lowered platform), no problems were observed.
When driving in Hi speed (with fully lowered platform), the left rear wheel seems to be blocked on forward. On reverse, it seems that is moving, but struggling. No issues with the left wheel.
The brake is releasing.
I checked the diodes at the hydraulic tray, seems OK. Then I have disconnected the cable of the coil of the Speed B valve, and the platform was driving on LOW speed only, no matter the position of the toggle switch, with no issues with the rear left wheel. Then I swapped the valves from the other lift I have, but nothing changed.
So, could you give some advise and what could be the problem.
Thank you in advance for your help.
  • Posted 5 Aug 2020 23:43
  • By Rosen_Bilchev
  • joined 5 Aug'20 - 2 messages
  • Bulgaria
Hello sir.
My 4632 is having the exact same problem 100% the way you described. my question is which valve, or valves did you have to clean, and how did you clean them.
Much appreciated.
  • Posted 29 Jun 2022 10:39
  • By Gino_Dandrea
  • joined 29 Jun'22 - 1 message
That's great!
  • Posted 14 Jan 2021 07:57
  • By Scissor_God
  • joined 30 Dec'20 - 26 messages
Scissor God
Shadow722@live.com 209-846-5836
Sorry for the late reply. I got it fixed. There was a metal debries in one of the valves. Got it cleaned, and no problems so far.
  • Posted 14 Jan 2021 05:24
  • By Rosen_Bilchev
  • Bulgaria
Did you get your lift fixed yet? I had this same problem and found the drive motor was broken.
  • Posted 14 Jan 2021 03:31
  • Modified 14 Jan 2021 03:34 by poster
  • By Scissor_God
Scissor God
Maxlion FB25LI
Enforcer FLBAXT25
