Speed control
Can anyone supply data on the zener diode fitted to the cableform panel on these tm 15 units ?
The machine takes off at full speed then cuts out, I've checked the pedal control and the black box both are ok
  • Posted 16 Sep 2006 04:29
  • By wonderphil
  • joined 6 Sep'06 - 15 messages
  • Mpumalanga, South Africa
Thank god for forklifts.
Did you ever find a repair for this? I have the same problem.
Thank You!
Ed
  • Posted 3 Feb 2014 08:10
  • By pineddy
  • joined 8 Jan'14 - 12 messages
  • Nevada, United States
Fix it like it's your own equipment!
Those controls are brutal.
Majority of jumping problems go back to jiggly connections at the plugs that go into the card.
If memory serves, there is an external transistor that supplies 10Volts to ????
apparently memory doesn't serve me well....
  • Posted 28 Sep 2006 15:15
  • By mike_n
  • Alberta, Canada
