Toyota 8FGCU15:
Spark plugs on a model 8FGCU15 fork lift
I have purchased a Toyota forklift used and am in the process of changing the spark plugs. some of the plugs seem to be galled in the aluminum heads if there a good way to remove them without loosing the threads in the head.
Second does anyone know the proper sparkplug of this model? It has a 9TIEB)2.204Y propane engine.
It has a W9EXR-U plug that seems too long.
  • Posted 22 Jan 2015 04:20
  • Discussion started by Kriege
  • Oklahoma, United States
The W9EXR-U/CU plugs come with the washers on them. I'm not sure you can buy just washers. They are installed first then the crush washer that is sort of crimped on there.
  • Posted 22 Jan 2015 10:18
  • Reply by mrfixit
That makes more sense than anything. Obviouly they did not install the copper washer when the last person changed plugs...Thanks a lot, i will be looking for the washers in the parts house.
  • Posted 22 Jan 2015 10:05
  • Reply by Kriege
W9EXR-U/CU have a thick copper washer on them along with the crush washer that keeps the plug from going in so deep.
  • Posted 22 Jan 2015 09:07
  • Reply by mrfixit
With aluminium heads I normally try & change the spark plugs with the engine slightly warm.
I did see a young spanner monkey at a car garage the other week using an air ratchet to remove & refit spark plugs on an aluminium head.
  • Posted 22 Jan 2015 06:59
  • Reply by Forkingabout
  • england, United Kingdom
Don't think so the threads look good up to the last two threads. they look burnt. So far I have removed one without trouble and the other has the last 3 threads full of aluminum, but the new plug went in fine and tighted OK. Still struggling with the last two. seem alwayfully tight.
  • Posted 22 Jan 2015 06:52
  • Reply by Kriege
Wonder if some idiot has put copper grease on the plug threads?
  • Posted 22 Jan 2015 05:40
Not sure on how to get them out without pulling the threads on them.
The actual Toyota number for the plug is 90919-01954-71 and it is a W9EXR-U.
  • Posted 22 Jan 2015 04:44
  • Reply by Partsguy5
Ice 28INCH-AUTO-SCRUBBER
USD8,350
JCB 533-105
edition #1228 - 1 May 2025
Louisville, KY, United States
Dubuque, IA, United States
Noblelift
Linda Häkkilä Linda Häkkilä
RAEDER-VOGEL
