Spark plugs on a model 8FGCU15 fork lift
I have purchased a Toyota forklift used and am in the process of changing the spark plugs. some of the plugs seem to be galled in the aluminum heads if there a good way to remove them without loosing the threads in the head.
Second does anyone know the proper sparkplug of this model? It has a 9TIEB)2.204Y propane engine.
It has a W9EXR-U plug that seems too long.
  • Posted 22 Jan 2015 04:20
  • By Kriege
  • joined 22 Jan'15 - 3 messages
  • Oklahoma, United States
The W9EXR-U/CU plugs come with the washers on them. I'm not sure you can buy just washers. They are installed first then the crush washer that is sort of crimped on there.
  • Posted 22 Jan 2015 10:18
That makes more sense than anything. Obviouly they did not install the copper washer when the last person changed plugs...Thanks a lot, i will be looking for the washers in the parts house.
  • Posted 22 Jan 2015 10:05
  • By Kriege
W9EXR-U/CU have a thick copper washer on them along with the crush washer that keeps the plug from going in so deep.
  • Posted 22 Jan 2015 09:07
With aluminium heads I normally try & change the spark plugs with the engine slightly warm.
I did see a young spanner monkey at a car garage the other week using an air ratchet to remove & refit spark plugs on an aluminium head.
  • Posted 22 Jan 2015 06:59
  • By Forkingabout
  • england, United Kingdom
Don't think so the threads look good up to the last two threads. they look burnt. So far I have removed one without trouble and the other has the last 3 threads full of aluminum, but the new plug went in fine and tighted OK. Still struggling with the last two. seem alwayfully tight.
  • Posted 22 Jan 2015 06:52
  • By Kriege
Wonder if some idiot has put copper grease on the plug threads?
  • Posted 22 Jan 2015 05:40
  • By Forkingabout
Not sure on how to get them out without pulling the threads on them.
The actual Toyota number for the plug is 90919-01954-71 and it is a W9EXR-U.
  • Posted 22 Jan 2015 04:44
  • By Partsguy5
  • joined 13 Jun'12 - 408 messages
Tampa Florida, United States
May CapEx Index falls Washington, DC, United States
Combilift Ltd
