some one help please crown fault 71
Hello , we have recently aquired a crown counter balance truck , Not sure but think its 6 years old.We are a small enginering company , I steam cleaned the truck , it now will not drive , displays fault 71, is there any one out there that can help ,
  • Posted 18 Jan 2009 16:54
  • Discussion started by roland_m
  • hertfordshire, United Kingdom
Best advise , Thanks
  • Posted 26 Jan 2009 16:23
  • Reply by roland_m
I guessI got no option but to put my hands up to cracked !!! I left the rear cover off over night , It didnt look damp , But next morning all worked fine , Thanks for your help
  • Posted 26 Jan 2009 16:22
  • Reply by roland_m
Thank you Justin, I left the rear cover off over night , It didnt look damp , But next morning all worked fine , Thanks for your help
  • Posted 26 Jan 2009 16:20
  • Reply by roland_m
it should be EV100
prob more like 10 years old
let me start of like this
NEVER STEAM CLEAN OR PRESSURE WASH ELECTRONIC MACHINES
or anything that has technology past the 60s for that matter
code -71 is no input from green wire to regen current sensor
there is something called a regen assy
next to the card there is a large heatsink with large rectifiers and a large capacitor (rectifier = large pigtail diode)
the regen assy is another smaller heatsink with 1 large rectifier and a current sensor
the sensor is a copper bar with 2 wires soldered to it (a green and yellow)
the wires are twisted together (twisted pair, like a telephone or ethernet wire pair)
make sure the green wire didnt come loose off the sensor
on the control card
there are 2 small plugs and 2 large plugs and a terminal board
in the smaller plug closest to the outside edge of the card you will find the other end of the green wire
this plug is called the PA plug
the green wire is in pin 5
sometimes if this plug gets dirty or oxidized (from the pressure washer) you can lose the connection or degrade it to the point the card cant read it
simply unplug the PA plug and plug it back in
this cleans the pins by scraping them
repeat this for the other 3 plugs as im sure youre washing would have had similar results on other pins
you should also use a good non-conductive electronic parts cleaner in the plug side
and pack them with a dielectric grease to prevent this from happening under normal circumstances (pressure washing would have blown this stuff away even if it was present before hand, after 1999 it was standard to pack the plugs at the factory)
again do not pressure wash the machines
even newer IC machine have computers that do have weather packed connections
but a pressure washer will get right past that without much effort
if you want take a picture of the control box and send it to my email (in my profile) i can label the pic of what you need to check and send some literature on what GE recommends to use to clean and pack the plugs
  • Posted 26 Jan 2009 13:01
  • Modified 26 Jan 2009 13:07 by poster
  • Reply by justinm
Pull off all the covers, dry everything with compressed air, especially inside the control card box, leave it sit for a day, and see if it runs.
  • Posted 26 Jan 2009 12:23
  • Modified 26 Jan 2009 12:23 by poster
  • Reply by Liftdoctor
  • Indiana, United States
Model and serial #might help also if known operation unit IE EV100 ect
  • Posted 19 Jan 2009 03:53
  • Reply by proshadetree
  • Tennessee, United States
Toyota 4FD240
SMV (Konecranes) 16-1200C
Airman ENCL045
Hitachi HX99B
VETTER Industrie GmbH
edition #1235 - 19 June 2025
