slow lift and lower
I'm having problems on a docket with lift and lower moving very slow. So far the pump has tested good (2k+psi)..it tested at 1kpsi on the lift side of manifold. I have swaped all liftrelatevalves with a known working truck. The speed is set to high through the computor. Also I swapped check valve and counter vabalence Val es
Anyone have any ideas on what else to check..I'm thinking possibly the manifold itself has an internal leak
  • Posted 16 Oct 2014 03:19
  • By kyle_z
  • joined 25 Sep'14 - 13 messages
  • Illinois, United States
yes kyle,
that sounds more like where the problem may have been.
something in the cylinders, maybe the safety valve might of been damaged or a cylinder problem would explain that symptom better :o)
  • Posted 27 Oct 2014 23:32
I did also swap the mast when I swaped the pump, mabey the cylinders could have had an internal problem? or mabey it was the check valves and the ones I swapped were bad, they were used check valves I found in some of our old parts. then the other trucks mast I swapped as a whole piece hoses and all and checkvalves
  • Posted 27 Oct 2014 04:00
  • By kyle_z
odd that this fixed it, good that it did
i can understand a pump causing poor lifting performance if worn out or defective but i don't see what it has to do with the lowering. The pump is not even in the equation when the lowering circuit is activated, well, unless this unit has regenerative hydraulics.
I've noticed some newer models what have this operation now like the regenerative braking etc in the drive systems.
yet another strange thing
  • Posted 27 Oct 2014 00:17
we have a spare parts truck, so I swapped the check valves on the cylinders, that wasn't it, then swapped the manifolds, that was not it, then decided to try the pump even though I thought it tested fine.. that fixed it.
  • Posted 26 Oct 2014 05:46
  • By kyle_z
Since lift and lower are both slow, that would indicate a possible problem with the proportional valve, or a really bad check valve in one of the cylinders. Something is restricting in both directions.
  • Posted 16 Oct 2014 14:44
  • By grego
  • joined 15 Nov'11 - 12 messages
  • Alberta, Canada
Sorry for all those typos..I'm posting from a phone that has some backspace issues
  • Posted 16 Oct 2014 03:20
  • By kyle_z
Muncie, IN, United States
Terberg YT220
Crown RD572513TT6860R
Kai von Berg Kai von Berg
Lift Technologies Inc.
