Slow drive when cold
Hi, need help with a Hyundai 25L-9A, has slow drive in forward and reverse until it warms up, then it will drive ok.
Pump pressure is good, handbrake valve and direction valve replaced. Valve block stripped and cleaned, but still have slow drive until warm.
Any ideas???
  • Posted 22 Jan 2025 04:21
  • By Dan81
  • joined 6 Feb'13 - 47 messages
  • Kent, United Kingdom
Yes, replace both
  • Posted 9 Jan 2026 23:54
  • By Dan81
Both directions movement clutch piston seals have caked, replace seals and machine will drive as designed.
  • Posted 9 Jan 2026 23:27
  • By Abayomi_Michael
  • joined 15 Jul'20 - 3 messages
  • Nigeria
Abayomi
Both forward and reverse clutch piston seals?
  • Posted 9 Jan 2026 23:22
  • By Chris_
  • joined 9 Jan'26 - 2 messages
  • United States
Hi, yes the problem was the clutch pack piston seals had gone hard and brittle. The clutch packs themselves were OK, just needed to replace the 2 seals, inner and out seals on the pistons.
Had 3 trucks all doing the same, must be a common problem.
  • Posted 9 Jan 2026 21:48
  • By Dan81
Did you find a solution for this issue? I'm having the same problem.
  • Posted 9 Jan 2026 02:27
  • By Chris_
  • United States
