Hyster S155SL/ B024D:
setting ignition timing
Hi working on this truck it has a v6 4.3l lpg engine, manual says use code mate switch i dont know what this is and i dont have one. someone advise using timing light or vacuum gauge. Thanks
  • Posted 13 Feb 2025 06:16
  • Discussion started by stephen_dwyer
still learning
Stephen,
This will depend on what year the truck is. Need last letter of serial number. If this has MSTS ignition, there is a connector near the MAP sensor that has a jumper in it, three pin amp connector. Remove connector and check timing at front pulley. It should read 0 degrees. If not, need to adjust. For the older units, there is a single connector that is for timing next to the distributor on the right side when looking at it. Disconnect the wire and again, timing should read 0 degree. Let me know if you need additional info. Remember to connect timing light to number one cylinder which is closest to the radiator. Good Luck.
  • Posted 17 Feb 2025 23:54
  • Reply by Fishmech
  • Virginia, United States
edition #1234 - 12 June 2025
Yale Lift Truck Technologies
JLG 450AJ
JLG 450AJ 2017
Flesherton, Ontario, Canada
SMV (Konecranes) 16-1200C
Lift Technologies Inc.
