Serial communication error
Hi. We have recently been experiencing difficulty using truck doctor. The software has been tested using the canbox on a r1.4 reach truck.
However when we use the truck doctor cable, direct through the serial port connection it doesn't see anything connected. We have tried, several different trucks, we have tried 2 different laptop, and we have also had a new set of cables.
It all worked fine until one day, its just stopped working and we cannot seem to workout why. Has anyone experienced anything similar?
The laptop runs windows 10 and the tablet runs windows 7 both have serial connections. We have also tried re installation of the software version 2.01.005.
We don't know what else to try.
  • Posted 21 May 2020 10:54
  • By elektrodrive
  • joined 2 May'08 - 752 messages
enquiries@elektrodrive.co.uk
Yes. Thanks usb to serial box worked and solved problem.??
  • Posted 10 Jun 2020 20:23
  • By elektrodrive
Hi
Have you selected com port 1 in the truck doctor program ?
  • Posted 10 Jun 2020 17:07
  • By Lindetech
  • joined 27 Mar'16 - 131 messages
  • Auckalnd, New Zealand
Jungheinrich incado found fault in cable and fixed. Thanks.
  • Posted 21 May 2020 21:24
  • By elektrodrive
And for the Jungheinrich trucks;
If you can,t connect(no project found)
you can by entering chascisnumber in partsprogram get the Catologe number and copy/paste this in the Judith program(right top corner)
  • Posted 21 May 2020 17:56
  • By John50
  • joined 7 Sep'19 - 155 messages
  • Netherlands
I'll try a usb converter box. Thanks.
  • Posted 21 May 2020 16:48
  • By elektrodrive
Use a usb converter and check comport in windows and in program,
i think you used different comport once on laptop and now it changed in windows.
In Truckdoctor you can tap the wrench icon, Configuration, and set which comport to use, that has to be the same as in windows Device Manager.
  • Posted 21 May 2020 15:18
  • Modified 21 May 2020 15:21 by poster
  • By John50
  • Netherlands
Lift Tek Elecar
