Toyota 7FGU25:
SAS LAMP
SAS light comes on with the key and stays on. There are no codes on the hr. meter. What do i check for? Thanks.
  • Posted 3 Sep 2014 22:59
  • Discussion started by Lift_Boyz
I would look to the swing lock solenoid and/or its associated wiring. Usually a solenoud will trigger an error though but its always a possibility.
  • Posted 18 Nov 2015 08:05
  • Reply by ray_k
Check the relay in fuse box, almost sure this can be swapped with another just to check them, Check mast and axel switchs also. Hope this helps
Give me model and sn I will give you part numbers for any parts
  • Posted 4 Sep 2014 00:09
  • Modified 4 Sep 2014 00:19 by poster
  • Reply by eoin_o
  • Co Tipperary, Ireland
