S1.5S. C442T03500S
Hi all
I have the following faults showing, appreciate any help.
Truck has a full battery, but not traction,lift or steering
Fault code CO 28946
EP0000
TR 00249
PU 00017
ST 00112
  • Posted 22 Jan 2025 18:55
  • By Paddyteclinde
  • joined 3 Dec'21 - 33 messages
  • Ireland
Paddy,
Code CO28946 is for failed brake. Turn key off for 10 seconds, then back on. If code returns, need to test brake coil ohms. Using ohm meter, should get a reading of about 50 ohms. Higher reading you need to replace brake. Cannot find anything else on the numbers listed. All codes will have two letters and 5 numbers. None of the numbers you listed are codes. Good Luck.
  • Posted 27 Jan 2025 23:21
  • By Fishmech
  • Virginia, United States
SMV (Konecranes) 20-1200B
Maxlion FB25LI
Noblelift
