runs like it has no power
good morning! i have a year 2000 7fgu25 toyota lift lp/gas i have done a tune up kit and replaced regulator hoping that would fix the problem. still running real sluggish. any ideas to cure this issue would be greatly appreciated. unit has 7,000 hrs
  • Posted 17 Jun 2025 22:35
  • By southerlandphil
  • joined 17 Jun'25 - 1 message
phillip southerland
Kind of sounds like you might have an issue with a lean or rich fuel mixture. Where the fuel hose connects to the fuel mixer [carb] there should be an adjusting valve that could have a small hex head about 8mm to adjust your fuel mixture. Toyota's had different types of valves. Could have a larger hex head type bolt with a jam nut or it might have a round valve with 2 flat sides for an open end 11mm wrench. You sometimes have to look underneath the housing because sometimes it's hidden. When you find it, start the engine and press the gas pedal to the floor and adjust it either direction until it smoothens out and runs good. Good Luck
  • Posted 27 Jun 2025 13:14
  • By mwjago
  • joined 20 Apr'25 - 15 messages
  • Montana, United States
mwjago
Trying to repair with out seeing truck is hard but in the back of the regulator there is a hose that goes to the regulator that hose goes to the resonator box pull that hose off and see if the truck has power l have seen that cause very slow pick up and a loss of power the box is there so at high speed it helps the diaframes in the regulator from vibrating.
  • Posted 21 Jun 2025 11:35
  • By Scott_
  • joined 16 May'21 - 320 messages
Scott
SMV (Konecranes) 20-1200B
Taylor TE650S
Australia was the first nation to successfully convert its paper-based currency to polymer banknotes, a technology developed in the same country. The first polymer banknote was a commemorative $10 note issued in 1988 to mark the Bicentenary. The first polymer banknotes were also the first to feature a transparent "window" as a security feature.
