Running Rich
Good Day,
Have a 30L-7A that runs rich when first started, will not build up any power to climb up small ramp at customers store, check engine light is on. is there any way to read the codes with out having to plug into the machine? i suspect the temp sensor may be the issue however, i do not really know location or specs for testing. A few other companies in town here have tried to troubleshoot this unit and have changed numerous parts but no luck and customer is getting frustrated. I'm a hyster/yale guy so Hyundai is new to me. If some-one can advise some info, it would be greatly appreciated! Thanks!
  • Posted 17 Jul 2019 14:03
  • By gbcurrie
  • joined 23 Jan'19 - 4 messages
You need check the oxigen sensores, but you need factory diagnostic and hook on.
Sometimes the EPR is gone and EPR is stuck and flow the gas to the mixer...same than Hyster system, (psi).
  • Posted 2 Sep 2020 05:11
  • By Rt210
  • joined 22 Oct'13 - 69 messages
  • BP, Hungary
I'm a beginner.
Crown SX3030TT4250
TCM FHD105Z
