resistor over heating
the resistor gets hot when battery is plugged in. wiring is okay contactors have been replaced motor test ok any sugestions where to look next. the resistor ohmed ok
  • Posted 1 Nov 2014 07:18
  • By leon_h
  • joined 1 Nov'14 - 2 messages
  • Delaware, United States
yes i do mean just that i will check it thanx
  • Posted 1 Nov 2014 21:54
  • By leon_h
Do you mean just sitting there and not operating it with the battery plugged in it gets hot? If so, then there must be a ground in one of the battery cables and one of the cables to the resistor. Unplug the battery and check to see if any of the cables on the truck show a ground to the frame.
  • Posted 1 Nov 2014 07:39
Just because the resistor ohmed ok dosent mean its good under a load or with current flowing thru it......when resistance goes down amperage goes up(ohms law) sounds like a bad resistor but maybe someone else has more thoughts on this?
  • Posted 1 Nov 2014 07:37
  • By kevin_t
Michel Denis Michel Denis
