Report this forum post
Problem: Right Motor, Faulty Armature Circuit (10)
(1) Situation
Indication: "10" display. Vehicle operation disabled.
(2) Possible cause
(3) How the error code is triggered
(4) Checks
Disconnect battery plug. Check line and regeneration contactor tips for wire breakage and melting. Make sure each
contactor tip moves freely. See page 1-37.
No broken or shorted wire Broken or shorted wire
(5)Check right motor armature wiring for wire breakage
and shorting. See page 3-15.
(18) Correct or replace faulty components (regeneration
contactor, line contactor).
(6) Check T1R IGBT, D1R diode, D2 diode and head
capacitor for abnormality. Check wiring between D1R
and logic card for abnormality.
See pages 1-46, 1-43 and 1-35.
Acceptable Unacceptable
(17) Correct or replace right motor, or correct or replace
wiring.
(7) Check drive board. Check wiring between T1R and
drive board for abnormality. See pages 1-44 to 1-48.
(16) Replace faulty components (T1R, D1R, D2, head
capacitor) or wiring.
Faulty right motor armature circuit, faulty line contactor, faulty regeneration contactor, faulty D1R diode, faulty D2
diode, faulty right motor armature wiring, faulty head capacitor, faulty T1R IGBT, faulty CS1 current sensor, faulty
wiring in other parts, faulty logic card, faulty drive board, faulty H bridge board.
Right motor armature fault is detected.
Software checks following signals and detects fault.
Pump Motor Voltage (CN2-34)
L. & R. Armature Voltage (CN2-39)
R. Tr. Voltage (CN2-41)
R. Armature Current (CN2-45)
Problem: Left Motor, Faulty Armature Circuit (20)
(1) Situation
Indication: "20" display. Vehicle operation disabled.
(2) Possible cause
(4) Checks
(5)Check left motor armature wiring for wire breakage
(6) Check T1L IGBT, D1L diode, D2 diode and head
capacitor for abnormality. Check wiring between D1L
(17) Correct or replace left motor, or correct or replace
wiring.
(7) Check drive board. Check wiring between T1L and
(16) Replace faulty components (T1L, D1L, D2, head
Faulty left motor armature circuit, faulty line contactor, faulty regeneration contactor, faulty D1L diode, faulty D2
diode, faulty left motor armature wiring, faulty head capacitor, faulty T1L IGBT, faulty CS2 current sensor, faulty
Left motor armature fault is detected.
L. Tr. Voltage (CN2-42)
L. Armature Current (CN2-47
  • Posted 9 Jul 2010 16:05
  • By gc_d
  • Zuid-Holland, Netherlands
Regards gc_d
Indicates mandatory field
Manitou M50-4
Maxlion R2D35
