Report this forum post
Find the Vickers valve assys mounted to the side of manifold...start by disconnecting the forward coil...if when you activate reverse..the machine drives forward...swap the 2 vicker valve assy's...should then drive forward and reverse but constantly turn on one direction...get a new bicker valve assy...if not when you disconnect the coil if it stopped, then diode probably bad going to wire number 16 for forward
  • Posted 12 Apr 2024 14:16
  • By Matthew_Reed
  • joined 12 Jun'23 - 113 messages
Indicates mandatory field
Hawker Powersource, Inc.
