replaced vaporizer, no real power forward or reverse
had an error code for vaporizer. replaced vaporizer, cleaned carb parts, idles and revs fine (even lifts) but has very little power going forward and reverse. ran fine prior to throwing code which happened while in use, then it was like it went to limp mode.
have coil packs over glow plugs?, all parts on carb seem to be electronically controlled (no adjustment screws and such that I can find)
any advice? having a tough time finding someone to come look at it.
thanks
model variation # MCP1F2A25LV
chassis # CP1F2-9P4607
serial # F810485
  • Posted 2 Oct 2018 01:37
  • By vapidorg
  • joined 28 Sep'18 - 2 messages
This is often related to the transmission, test disconnect the temperature sensor of the transmission and then the speed sensor. But you must be more explicit with the code
  • Posted 18 Jan 2019 11:52
  • By delga76
  • joined 20 Oct'16 - 22 messages
UK names its first Logistics Minister Leicestershire, United Kingdom
Yale hosts dealer showcase in Germany Mörfelden-Walldorf, Germany
Alogotransiphobia is the fear of being caught on public transport without a book to read.
edition #1294 - 13 August 2026
In this week’s Forkliftaction News, we report on Jungheinrich’s H1 financial results and the reasons it has adjusted down its EBIT forecast for the year... Continue reading
