Removing Power Steering Cylinder
Hi all, first post here in a couple of years. We have a Hyster E30XL at work that started leaking fluid out of the Power steering cylinder. So we're looking for help getting the cylinder tie rods off the steering knuckle. We have the pins out (after several hours) and the tie rods are loose on the knuckle brackets but we can't get them to come out. What is the secret to removing them? Is there some kind of channel that the knuckle has to be turned a certain way and the tie rod just slides out? We did try to turn the knuckle so the tie rod was perpendicular but that didn't seem to do anything. Any help would be greatly appreciated. Thanks in advance for any help.
  • Posted 26 Jan 2024 05:12
  • By MaintenanceRon
  • joined 6 Jan'24 - 8 messages
Ron
Thank you, we were glad too!
  • Posted 31 Jan 2024 22:29
  • By MaintenanceRon
Ron
Glad you got to the bottom of it
  • Posted 31 Jan 2024 00:10
  • By Scott_
Scott
It appears we just weren't using enough muscle. I pried them both off this morning.
  • Posted 30 Jan 2024 03:43
  • By MaintenanceRon
Ron
Thanks for the reply Scott. I'm attaching a photo of the knuckle we are having trouble getting off. It is lose on the steering knuckle but will not come away from it. There is no nut holding the tie rod, just the single pin on either side. Is this what you thought we had?
https://photos.google.com/search/_tra_/photo/AF1QipPmwtqNhb872Rq7nqHm5MFca57p_wOkAFYg815L
  • Posted 29 Jan 2024 23:48
  • By MaintenanceRon
Ron
If you removed the two pins to the tie rod to the steering axle then the tie rod were the pin was should pull out to you that will release the tie rod than take the nut off the tie rod and hit the joint to separate
  • Posted 27 Jan 2024 08:24
  • By Scott_
Scott
Maxlion FDR45
Enforcer FD50T-MMA
