remove torque converter?
Cant remove torque converter from a komatsu fg25-11. Usually a tc will just slide out of the pump and off the input shaft, but this one is stuck hard. Is there some special trick on this lift?
  • Posted 30 Aug 2014 15:32
  • By josh_k
  • joined 26 Aug'14 - 14 messages
Thanks! I wish I heard this a few weeks ago. You are correct, once I figured this out it was no problem.
  • Posted 14 Oct 2014 07:10
  • By josh_k
on the back (engine) side of the converter is there a series of bolts around the pilot shaft? if so remove those bolts. under that cap there is a snap ring that must be removed. hope this helps...
  • Posted 14 Oct 2014 06:50
  • By DennisW
  • joined 10 Sep'09 - 21 messages
Terberg YT222
Toyota 4FD240
Terberg YT222
Toyota 4FD240
