red wrench light is on
LPG Toyota 8FGCU25. How do I reset the red wrench light. There are no buttons on the display. I replaced the fuel regulator and filter. Changed the oil and filter and would like to reset the wrench light.
  • Posted 10 Aug 2019 00:26
  • By Chris_Chase
  • joined 10 Aug'19 - 2 messages
  • North Dakota, United States
Chris Chase
Remove the negative battery cable from battery for at least 10 seconds. 2 minutes to be safe and reconnect cable. I clear my codes this way when the problem has been fixed.
  • Posted 30 Oct 2019 05:47
  • By Eedy1
  • joined 25 Oct'19 - 9 messages
I have an 8FDU30 Toyota with a wrench light displayed on dash. I assume it has a code but on a Toyota Diesel I do not know how to access the code or get it displayed. A wrench light doesn't tell me much.
  • Posted 6 Sep 2019 07:48
  • By Whitebuzzbait
  • joined 21 May'12 - 15 messages
You may still have a reoccurring hard code.
  • Posted 10 Aug 2019 05:31
  • By BREWSKI
BREWSKI
Yes. Tried jumping the Tc and E1 pins at the DLC with the negative cable disconnected and then reconnecting it and turning the key on and pressing the accelerator pedal 5 times.
  • Posted 10 Aug 2019 05:29
  • By Chris_Chase
Chris Chase
Have you tried disconnecting the battery for a few minutes? This will reset most trucks.
  • Posted 10 Aug 2019 03:45
  • By BREWSKI
BREWSKI
