Reach truck. No travel after warm up
Hello. I have a Yale reach truck (not sure of the model at the moment) that according to the report I got, the truck hydraulic functions are Ok but when the truck warms up there is no travelling forward or reverse. When the truck cool down, the travelling works again.
Not really an expert on Yale trucks, can anybody help me with some ideas?
  • Posted 1 Jul 2016 13:15
  • By CarlosCol
  • joined 13 May'16 - 28 messages
  • Bogota, Colombia
need to fix that display problem
also check the thermal sensor on the drive motor
  • Posted 11 Jul 2016 04:32
Guys, thank you for your input. I checked the truck but the suplemental display is not working (it has a message that says (no communication with the MIB or something like that) so I don't know if there is a error code. I will check the fans on the next opportunity I have. THanks again
  • Posted 7 Jul 2016 23:11
  • By CarlosCol
  • Bogota, Colombia
It sounds like the thermal cut out is being operated in the controller, I would have thought a fault code would have been displayed. But there is a tunnel fan located between the finger control levers and the SEMS controller and starts running as soon as the the truck key switch is turned on and dead man switch operated. It blows cool air down the fins off the SEMS controllers sometimes these fail also they can get clogged up with dust and debri. Cleaning them out sometimes gets them going again. I hope this helps.
Regards Nero.
  • Posted 6 Jul 2016 18:35
  • By NER045
Does this truck have a led display panel? If it does it should show a warning or fault code when it is not operating correctly. I believe this has a Curtis SEM controller. If no faults are displayed it probably is a faulty controller.
  • Posted 2 Jul 2016 00:05
  • By BREWSKI
Truck model NDR030GANL36TE143
Serial no A861N01601X
  • Posted 1 Jul 2016 22:46
  • By CarlosCol
  • Bogota, Colombia
Michel Denis Michel Denis
