reach truck mini lever not working
fault codes 228-01 and 228-33......NO CAN MSG A..... I swapped the mini lever and tested it on another truck, it works, i did the same to the VCM module and it also works.....i checked the harness between the mini lever and the VCM module for continuity and seems ok..please i am pleading, any help ?.....thanks
  • Posted 2 Aug 2024 19:15
  • Modified 2 Aug 2024 21:17 by poster
  • By northstar
  • joined 16 Jun'17 - 92 messages
  • accra, Ghana
North,
Since the lever and module are good, there is an issue with one of the connections. You will need to remove the wires out of the connector and inspect each crimp. Also look for any corrosion at all connectors. You may be able to read ohms at all connections, but the wire may not be able to carry voltage needed. Good Luck.
  • Posted 19 Aug 2024 22:35
  • By Fishmech
  • Virginia, United States
Sue Tomic Sue Tomic
UN Forklift FBRP15NQZ2
Terberg YT223
Sue Tomic Sue Tomic
