Reach/ Retract malfunction
If anyone could help me out with this problem I would greatly appreciate it. I have an rr 5200s having a problem with reach and retract when using thumb wheel to reach will only reach and retract the one time after that gets stuck, then you have to rekey machine each time.
  • Posted 15 Dec 2013 04:40
  • By stucktruck
  • joined 27 Nov'11 - 17 messages
  • New Jersey, United States
sounds like a break in the wire inside the insulation on cable that goes to the reach solenoids, either over the mast cables or on the reach carriage itself.
  • Posted 15 Dec 2013 23:49
Unfotunately it is not shutting down however we just replaced m2 and pump so i figured maybe the valves needed to be recalibrated, when i try to recalibrate gets code 254 so i followed the flow chart still nothing.
  • Posted 15 Dec 2013 21:57
  • By stucktruck
If it is shutting down, you probably have a code. Troubleshoot the code.
  • Posted 15 Dec 2013 13:54
  • By Liftdoctor
  • joined 22 Jan'05 - 115 messages
  • Indiana, United States
Crown WP302020
Maxlion ESD15M
