RD5000 no reach or tilt functions
the pump loads up when thumb wheel is applied to reach or tilt but no movement. I've check continuity to the first junction block at base of mast and wires are good over mast but not sure where to check from there to ??
  • Posted 10 Oct 2014 08:29
  • By troy_m
follow the wiring out of the junction block, it should run to a function manifold probably underneath a cover on the carriage with several solenoids on it. Most reach trucks are setup this way.
Check signals at the function manifold
  • Posted 10 Oct 2014 21:36
SMV (Konecranes) 4531CC5
Toyota 8FG25
