Raymond RTW30 S/N RTW-05-02094
Truck sparks when you plug in the battery but only with capacitors fully discharge. Is this a common problem on this truck? truck has been checked for shorts to frame motors contactors horn etc.. resistance on frame above 1000ohms.componets to frame. has anyone come across this problem for this truck?
  • Posted 7 Mar 2013 09:27
  • By ben_g
  • joined 12 Feb'08 - 60 messages
transforker do you have an email address?
  • Posted 26 Apr 2013 07:05
  • By forktech418
  • joined 31 May'12 - 19 messages
had a similar problem with that truck.
my particular case , it was that battery had some play in compartment, and when moved back the truck, there is a still bar
right at posts (b+ and b-) that makes a small contact.
my customer frecuently commented about that, however,din not ask me to check it out. the final result it was, the traction controller damaged.
  • Posted 9 Mar 2013 13:26
  • By ARgo5
  • joined 28 Nov'12 - 26 messages
  • nuevo leon, Mexico
Terberg RT223
Factory Cat MICROMAG20D
