raymond reach model ezr40tt error code 45
Ezr40tt is showing error code 45 and is inoperable.
  • Posted 19 Apr 2014 06:08
  • By hoang_h
  • joined 28 Mar'14 - 11 messages
  • California, -
hoang
Turns out just a relay was disconnected, possibly kicked loose by neglect driver. Fixed. Thanks
  • Posted 28 Apr 2014 03:42
  • By hoang_h
  • California, -
Pump contactor detected open when commanded closed.
It's physically stuck. points burned, wiring to it bad. CHECK FU8 fuse first. With voltage not ohnmeter!!! Jumper it if your not sure, or use known good fuse. It will test ok with an ohmeter, but still be bad! PC sense line may be bad. Check for continuity from TP7 to JS14-8
Worst case, System card and VFC. Rare
I hope there is not a remote switch for lifting a cage?
  • Posted 26 Apr 2014 10:30
  • By EasiTek
