Hey guys,
I have a Raymond 102XM that is flashing this error code E118, but I cant find any info on this error code. Walkie wont do a thing completely dead in the water. Battery seems good, cant see any obvious problems. Has anyone ran into this error code?
Scott
just an FYI on this E118. I had one today and I tested the batteries with a load tester 3 of 4 tested on the edge of weak. Then I did pairs and got the same result. I was going to plug in to the truck and see if there was any difference in the voltage drop and when I plugged in the batteries the truck powered up. I am planning on replacing the batteries.
no, thank you for posting the solution!
This is going to sound a bit silly but the problem was low battery. The operator told me the battery was fully charged and I believed him. In the past the first thing I would do with any error this machine would through at me was charge the battery, and 9 times out of 10 low batteries was the problem. But thanks for your inputs, its nice to know there are people out there who can give advice when in a pickle.
Scott
Looks like this truck has a BT Rolatruc tiller head on it & is also a clone of a Toyota truck.
this is part of the RPIN that has a bunch of new codes!
tell me more about your problem so i can help. also toy PJ have similar codes.
have you searched them?
