raymond easi r40tt
serial EZ-D-03-28452
error code 5G. not too sure on the operational issues but it has shown a 59 code also.
Does anyone have any ideas?
  • Posted 31 Aug 2010 04:27
  • By mowers
  • joined 29 Jan'10 - 27 messages
  • Alberta, Canada
after the local Raymond tech inspected and diagnosed a blown traction amp, we looked a little deeper and found 2 dry solder joints inside the main plug for the amp. Saved around $3g's...
Thanks for the help
  • Posted 21 Sep 2010 01:49
  • By mowers
  • Alberta, Canada
thanks,
I'll see what I can work out and let you know
  • Posted 31 Aug 2010 06:10
  • By mowers
  • Alberta, Canada
These are both CAN BUS errors. Make sure to check for shorts to frame and battery voltage to frame. Check your connections at the traction and lift amplifiers and also for the lit LEDs on both. If it's intermittent it can sometimes be caused by the K3 relay or the relay card itself.
  • Posted 31 Aug 2010 05:48
  • By joe_d
  • joined 25 May'10 - 253 messages
Ain't nothing I can't fix but a broken heart and the break of day!
