Raymond EASI - NO reach, tilt, or sideshift. ( sometimes ) NO codes
Hello all,
Raymond EASI ,NO CODES Has no auxiliary functions, Has Lift/Lower, Contacts and pump are running when control handle is used. If you activate the lift a little bit it seems to help. Anyone run into this problem.????
  • Posted 13 Jan 2010 06:36
  • By Prentice
Yes the 6 wire cable that goes threw the mast assembly was the problem. got confused with the reach not working. Usually the tilt and side shift start acting up. Thanks for the great advise and quick response.
  • Posted 15 Jan 2010 23:37
  • By Prentice
GOT IT.......I think. The mast cable was cutting out power when the mast was lowered. Parts on order. Will let you know soon, if that was the ticket.
  • Posted 14 Jan 2010 07:10
  • By Prentice
Yes, also check the Over The Mast Cable, and the through the pentagraph cable
The Handle test is quick..
Do you know the superword?
  • Posted 14 Jan 2010 01:02
  • By JonG
  • joined 7 Nov'07 - 155 messages
  • United States
the filter is under the access cover on top ( the large cover that covers the lift motor, hyd. manifold, and line filter.
  • Posted 14 Jan 2010 00:18
  • By just_m
  • joined 13 Jan'10 - 9 messages
sorry I didn't see "sometimes" in your description. Try that, check control handle, and then check " check over the mast cable".
  • Posted 14 Jan 2010 00:16
  • By just_m
Which Cover??Is this in the hydraulic manifold??Hyd Filter??
  • Posted 13 Jan 2010 23:48
  • By Prentice
easy one,
there is a fuse in a filter under the cover. the filter is large, black and blue in color, and the fuse is under a grey plastic screw on top. When this fuse blows, you will lose all aux. functions, get no codes, still travel, and still lift. Try it. Oh yes, it is a slow-blo fuse.
  • Posted 13 Jan 2010 22:55
  • By just_m
Sounds like you have a bad control handle. Did you run the tests on the aux function switches?
I can get you more detailed info with a better make and model and SN
  • Posted 13 Jan 2010 11:13
  • By JonG
  • United States
UN Forklift FD30-35T
December 03, 2025 - New Delhi, India
Lee Rushton Lee Rushton
Yale Lift Truck Technologies
