Raymond 470-C50HM E2 code
Hello
I have a unit with a E2 code, What should I be looking for and does anyone have a Service manual for this unit. I be willing to trade
  • Posted 18 Dec 2013 03:24
  • By JimB
  • joined 12 Apr'13 - 30 messages
bhdjim at yahoo dot com
Hi, I was reading your post, hopefuly you can help me out, I'm having problems with one of this units, and have no manual, I was able to get the information of code 28 a problem with the steer pot. I may need to run the learn program, can you tell me the complete steps to perform the alternate learn method. thank you for sharing the information it is very helpful.
  • Posted 22 Apr 2014 02:59
  • By pelayos1
  • joined 20 Sep'11 - 8 messages
pelayos1@msndotcom
i work on alot of 4700's and they are not bad at all. They are very susceptible to static. 9 times out of ten, it just needs a relearn. the other is adjusting the pot. But first, visually check the plastic articulating arm that is connected to the lift pot, that it is not cracked or broke. You can use a alternate method for relearning by pushing the speed mode and turtle mode switches.
  • Posted 3 Jan 2014 00:31
  • By just_m
  • joined 13 Jan'10 - 9 messages
the 4700 is the biggest pain in the butt for any raymond tech out there.
you can take the cover off the hyd. control levers. on the lift lever you'll see the pot and linkage. loosen the allen head screw the hold the the pot shaft. pull the lift handle back and use a small flat blade screw driver and adjust the pot until the code goes away and the lift lifts at full speed. tighten the allen screw and release the handle. thats the quick way to get around calling the dealer.
  • Posted 28 Dec 2013 01:33
  • By Madfish
  • joined 16 May'12 - 22 messages
  • Missouri, United States
your going to need the dealer to come out with a laptop. this is a constant problem on these units blamed on static. they lose their learned values and the truck needs to be reset to default then all configurations reset and learns completed. with that said, is your static strap ok? your lift/lower pot may be bad as well. IMO truck is a pos. dual drive on a 4 wheel electric... great idea (I say that as sarcastically as possible)
  • Posted 21 Dec 2013 01:21
  • By stam
Does anyone have a manual for this unit??
  • Posted 20 Dec 2013 23:17
  • By JimB
Tacoma, WA, United States
Highland, IL, United States
Orlando area, United States
Jan Zuurbier Jan Zuurbier
Global CEO, Swisslog
Board member, UKMHA
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
Hitachi HX64B2
Nagano NUZ090D
September 4, 2025 - Melbourne, Australia
September 17-18, 2025 - Miami, FL, United States
October 21-23, 2025 - Barcelona, Spain
