Raymond 102 XM hydraulic issues
All,
Pretty stumped on this current issue. The walkie pallet jack moves forward and back fine. Hydraulics seems to malfunction periodically. Sometimes it will lift and other times it won't. No error codes are displayed and I have already replaced with a new lift solenoid. I've checked the hydraulic fluid levels and it seems to be fine. I've also swapped the handle with another one from a working pallet jack and continue to have the issue. Could it be a problem with the hydraulic pump? Are there any additional areas i need to check for wire shorts? Any help is greatly appreciated.
Robert
  • Posted 14 Jun 2012 13:08
  • By Blobby
  • joined 14 Jun'12 - 2 messages
Check ur lift limit switch and wiring.
  • Posted 12 Aug 2012 01:07
  • By stam
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Toyota 8FG25
Lift Tek Elecar
