Raise/Lower
Hello all, I have a Crown Wav, and everything functions as it should it turns on and moves forward and back but it will not go up or down, from the handset or the control switch at the base, the switches have no response they are sending a signal as I tested for continuity but it has no response, please help.
Thank you
  • Posted 15 Jan 2021 00:49
  • By ManRandy
  • joined 4 Jan'18 - 6 messages
  • Michigan, United States
Thanks for the reply I was able to find the problem 2 of the wires for the lift were being shorted out in the harness under the footswitch so I just crimped them together and it is working thanks.
  • Posted 16 Jan 2021 06:09
  • By ManRandy
Have you checked the main fuses located near the bottom of the mast? I would start by checking for voltage at the small lift solenoid terminals while attempting to lift
  • Posted 16 Jan 2021 02:04
  • By Triggs
JCB 533-105
Mitsubishi Logisnext FD25T5M
