Crown PE4500:
precharge fault code 33 on PE4000 pallet jack
im thinking iot the controler used hanset every function work except line contactor doesnt pull in its got power to contactor.. i replaced coil..and same.. anybuddy seen this????
  • Posted 3 Dec 2011 04:55
  • Discussion started by irrk1
If the pump solenoid is stuck. It will cause the line contactor to drop out after key on. Tap the solenoid.
  • Posted 8 Jan 2014 08:10
  • Reply by Tiki
the Controler was bad...
  • Posted 4 Jan 2014 10:12
  • Reply by irrk1
Is the pre-charge resistor getting "HOT",when the battery is plugged in? If so,check the pump motor solenoid,and make sure it's not stuck closed.
  • Posted 14 Dec 2011 14:45
  • Reply by Truck_Tech
  • United States
Linda Häkkilä Linda Häkkilä
edition #1228 - 1 May 2025
