poor hydraulic steering assist
unit will not steer no power assist when turning steer handle did have orbital replaced no difference
  • Posted 6 Dec 2008 12:12
  • By rick_o
  • joined 7 Nov'08 - 33 messages
How full should the hydraulic oil reservoir be when not in use?
  • Posted 24 Oct 2023 14:09
  • By Ron_Wright
  • joined 24 Oct'23 - 1 message
  • Washington, United States
Ron
Does the steer motor run, but very slowly? Sometimes the steer motor brush springs loose their tension. I replace the springs every time I do brushes, that usually takes care of it if the armature is OK.
  • Posted 26 Feb 2010 16:38
  • By CSCFR
  • joined 26 Feb'10 - 22 messages
Jerry
Any Idea where I can get a repair manual? I don't have a clue what the SVA or torque generator are. Thanks for your time.
  • Posted 26 Dec 2009 21:40
  • By palletman
  • joined 25 Dec'09 - 1 message
  • Minnesota, United States
thanks,found valve not functioning,had power through valve no function
  • Posted 9 Jan 2009 11:35
  • By rick_o
Yes I did. Thanks Marty b, type-o. Thats what I get for replying at midnight.
  • Posted 9 Jan 2009 00:26
  • By roadtek
  • joined 4 Dec'07 - 123 messages
Roadtek: do you mean SV1? the valve on the torque generator?
  • Posted 8 Jan 2009 23:46
  • Modified 8 Jan 2009 23:47 by poster
  • By marty_b
  • joined 12 Dec'08 - 4 messages
Make sure SVA in the torque generator manifold is functioning. Without it you will have no steering. Do you have tilt and sideshift if so equiped?
  • Posted 28 Dec 2008 11:26
  • By roadtek
check to see if the steering race (big round bearing) is binding
do you have 1200 psi when you try to steer/ (check the pressure if steer race is ok.
Is the chain good?
  • Posted 12 Dec 2008 23:03
  • By marty_b
REPOWERTEK Inc
