PMT trip
I have a 1987 TM12 that trips the pmt when the throttle is pushed just before the 1A the scr speed seems slow also. Itwill not turn the wheels on the ground but will with the wheel up. It takes off real slow and kicks the PMT twice before quiting all together. Could it be the throttle assm.?
I tried a #2 scr and the #1 src checks good.
Thanks
  • Posted 4 Nov 2008 04:31
  • By KimM
  • joined 4 Nov'08 - 3 messages
Thanks Justin, The truck is an inside only truck and I did check most of what you suggested. The #2 checked bad and I have seen in our Crown TS trucks when one goes they both go. Thank you again.
  • Posted 7 Nov 2008 09:39
  • By KimM
Mr. Kim
make sure all the bars and wire connectors are clean
or if you take em out it would be a good idea to wire brush them
ive seen machines do the same thing from dirty connections (less than a year old machine ev100zx)
you might have cleaned them a little just by loosening and tightening them
if the issue returns wire brush all the connections between the 2, 5, the capacitor, choke/ reactor, and the spider assemblies
(for EV100 system)
  • Posted 7 Nov 2008 09:09
  • By justinm
Got it thanks, it was the #2 scr and the # 5
  • Posted 5 Nov 2008 21:09
  • By KimM
Autolift E180AT36B-D5-180
Aichi SR10C1SM
