Only moving forward with the lever in neutral, forward and reverse.
Hello, I have a forklift Bendi Series IV with Navitas system, the problem that arises is that only moves forward, and calibrate the potentiometer directional and reinstall the program with the scanner Probit, if I put the lever in the posocicion reverse, accelerationHe begins to move forward, but if I accelerate more, insofacto reversed. no longer do you test someone to share experience this problem as solved. thanks
  • Posted 15 May 2015 12:45
  • By RGAMEZO
  • joined 3 Nov'14 - 5 messages
  • Jalisco, Mexico
The Engineering in continuous action
