Old Clark forklift CFY40B parts source
Hello:
Been watching this site for a little bit before buying a forklight. I have a hobby farm & need a forklift with rough terrain tires for occasional yard work. Just picked up a Clark CFY40B LP with double stage lift. Really happy with it.
Been on Google trying to find a source for future parts (and manual). Figured I may as well make a post here requesting help for a good parts source. I'd like to have a source with a picture catalog if possible.
I plan on repainting(restoring) the unit and will need CLARK stickers etc. The unit has a 12 volt system and my only concern is the loose steering, I can see that the steering link kuckles (or ball sockets?) are loose on the main steering shaft. They also look like they have threaded/adjustable fitting. Maybe I can turn them in some.
On another note:
I'm in a good spot living on the international border with Quebec, Canada and Champlain, NY (I-87 in NY and 15 in PQ) for anyone needing a staging point or drop off point for cross border goods. Vermont is only 3 miles east.
Can also help with transportation and delivery now that I'm retired.
Thanks
Ed
  • Posted 17 Jun 2007 12:55
  • Discussion started by ZipTow
You really do not need a diagram. These are very simple units. The ignition wire for the coil comes directly from the key switch ign. terminal.
  • Posted 3 Apr 2017 22:22
  • Reply by BREWSKI
I've got a late 60's Clarke CY40B. Started running rough and then quit. After checking a few things it seems there is no spark. Does anybody out there have wiring diagrams for this unit?
Thank you.
  • Posted 2 Apr 2017 02:16
  • Reply by abi24
Not sure if this is the right forum, I bought a old cfy40B clark lift. need to find out where i can get inexpensive parts. also steering has a lot of play is there any easy fix for this looks like the steering box has a lot of play. can the steering box be replaced or rebuilt.
Thanks
  • Posted 19 Dec 2008 08:28
  • Reply by tema
By the way, I work part time for an outfit that makes distributors and certain electronic ignition components for automobiles. If there is a need for a common distributor or electronic component that is hard to find or expensive let me know, our outfit is always looking to expand. Any need for points to electronic ignition systems? Of course, the more of a specific application the better production chances.
Can't guarantee anything, but if I don't ask, I won't get an answer.
Ed
  • Posted 22 Jun 2007 10:23
  • Reply by ZipTow
LOOK ON THIS SITE
We have a storefront WWPARTSLINK
  • Posted 22 Jun 2007 06:43
  • Reply by darryl_w
  • Quebec, Canada
Parts finder expert
Tom W
You are right on, the steering is a real challenge, poor design. I'm looking forward to correcting it.
I need to locate a manual, don't even know what the shift pattern is, or where the various fluids go. Just started it, drove it off the trailer and parked it. Also my first experience with LP, not as responsive as a gasoline carbed engine.
It really runs good but lacks power...can the LP unit be adjusted to flow more LP?
  • Posted 22 Jun 2007 05:58
  • Reply by ZipTow
darryl w.
I work (part time) for a Canadian company based out of Montreal on Henri-Bourassa Blvd. E.
They have a company down here in Champlain, NY.
Can you give me contact info?
thanks
Ed
[email address removed]
  • Posted 22 Jun 2007 05:47
  • Modified 22 Jun 2007 05:59 by poster
  • Reply by ZipTow
WE HAVE THE BOOK CAN GET THE PARTS
WE ARE ALSO NOT FAR FROM YOU
DORVAL AIRPORT QUEBEC
  • Posted 22 Jun 2007 04:20
  • Reply by darryl_w
  • Quebec, Canada
Parts finder expert
The numbers Ihave are: CFY40B 69-445
thanks.
Ed
  • Posted 22 Jun 2007 03:06
  • Reply by ZipTow
what's the serial number on that unit. i might have some part info on it.
  • Posted 21 Jun 2007 23:33
  • Reply by steve_c
  • Illinois, United States
The Clark CFY40B was in its day a tough unit. However, the steering was a real issue with these units. The steering has so many rods, levers, bell-cranks, connections, etc that it is almost impossible to remove all the "slack". Just a little movement in each connection adds up to a half-turn by the time it gets to the steering wheel. It can be improved, but, it will take a lot of money and/or time to make a big difference.
On the note of parts....your local Clark dealer can help you with a parts book and service manual.
Good Luck!
  • Posted 21 Jun 2007 23:03
  • Reply by tom_w
  • Virginia, United States
Architect Gustave Eiffel originally submitted his design for the Eiffel Tower to Barcelona but the city rejected it for aesthetic reasons. As we know, he had more success in Paris, however, his plan was far from popular at the time.
FT-Myers/Naples area, United States
Kortrijk, Belgium
East Peoria, IL, United States
St. Louis, MO, United States
Joseph E Creed Joseph E Creed
CEO, Caterpillar Inc
Secretary general, European Rental Association
Chairman of the Board of Directors, UgoWork
June 24-27, 2025 - Lima, Peru
August 1-3, 2025 - Coimbatore, India
September 16-18, 2025 - Dar Es Salaam, Tanzania
