Not lifting passed first stage.
Our Linde H40D recently had a load that was too heavy for it and it tipped forward with all the weight. Now it will not lift anything passed the first stage. Everything works fine without a load. Is there a sensor or something that I should look for? Thanks.
  • Posted 27 Feb 2025 23:24
  • By Kirt_Forsythe
  • joined 27 Feb'25 - 3 messages
They leak internally. You might check the gland at the top of each cylinder. There is a 10 mm bleeder screw. If you remove the screw and and fluid pours out then the cylinder is leaking internally and needs to be repacked.
  • Posted 7 Mar 2025 22:41
  • By duodeluxe
  • United States
duodeluxe
Everything is still straight, as far as I know nothing broke. I don't see fluid anywhere. I'll have to look into rupture valve. I have never heard of that before. Thanks.
  • Posted 7 Mar 2025 21:54
  • By Kirt_Forsythe
KF
Even if they are not leaking?
  • Posted 7 Mar 2025 21:52
  • By Kirt_Forsythe
KF
My guess is that the secondary lift cylinders need to repacked.
  • Posted 7 Mar 2025 01:08
  • By duodeluxe
  • United States
duodeluxe
if everything is still straight ???? and no bearings are broken?
in each cylinder there is a hose rupture valve 1 of them is broken
  • Posted 6 Mar 2025 17:01
  • By michel_v
  • noord holland, Netherlands
Aichi RX07B
Ncn 110TH
Ncn 110TH 2015
