Not Charging
I have a Yale pallet jack model # MPB040EN24T2748 that will not charge. 3 of the 4 batteries were changed for new in February of 2015, the 4th was changed last week, when plugged in to charge it would go though the initial check and get to the point were the yellow light would flash showing that it is checking the batteries, after a few minutes I would get 3 flashing lights showing severe discharge. I checked all batteries and they were at 5.9 volts, I put all on a charger individually and now there charge is at 6.2. before I charged them I had no lift, after charging the lift is now working. but when I plug it in to charge I'm still getting the 3 flashing lights.
  • Posted 21 Oct 2015 07:20
  • By msuro
  • joined 12 Jun'13 - 6 messages
  • New Jersey, United States
Is the brand name on the charger Moran? If it is it needs to be replaced.
  • Posted 29 Oct 2015 06:14
  • By BREWSKI
I checked the voltage with a multi meter and it was 24v after plugging the charger in the yellow light flashed for quite awhile then all 3 red lights started flashing, the voltage was still reading 24v
  • Posted 27 Oct 2015 04:23
  • By msuro
What happens to the voltage when you plug in the charger?
  • Posted 27 Oct 2015 00:06
  • By BREWSKI
Taylor TXB180S
Crown SX3030TT4250
Taylor TXB180S
Crown SX3030TT4250
