Not being detected
Have bought hyster pc service tool version 4.95 and the previous version was 4.91 when trying to connect to the truck using pc tool the model is not available from unit code section any assistant will be of great help.
  • Posted 14 Sep 2020 13:42
  • By Joshua_Mwanjala
  • joined 14 Sep'20 - 4 messages
  • Kenya
JM
Hi,
where did you buy the PC Service Tool and was your previous version good for a series A285 lift? I'm told my Utilev UT25P can be accesssed using the H-Y PC Service Tool but there is so little support for this brand. Thanks, mike
  • Posted 5 Feb 2022 09:52
  • By MICHAEL_SPOSATO
  • joined 5 Feb'22 - 8 messages
  • New Mexico, United States
Mike Sposato
Dear Sir, I trust you are well today, kindly advice me where can i get this Dana dashboard for
transmission, and does it use same Hyster diagnostic cable different one kindly advise.
  • Posted 9 Oct 2020 09:19
  • Kenya
JM
Dear Sir,
I trust you are well this morning, thanks for the information will share with our Mechanic regarding the same, as per your advice.
  • Posted 29 Sep 2020 16:07
  • Kenya
JM
most likely Hyster has removed support for the XM series you have as it doesn't need pc service tool to read codes etc check teh patch notes with the update. when i worked on them we never used pc service tool as codes all come on dash and once fixed codes went away. We did use dana dashboard for the transmission every now and again but it was rare hope this helps
  • Posted 25 Sep 2020 16:27
  • By Applez
  • joined 25 Sep'20 - 3 messages
  • Victoria, Australia
Crown SX3030TT4250
UN Forklift FD50T-NJB3
