No Traction
Hi guys, the track operates well for a few hours then it stalls. The engine performance well, no diagnostic trouble codes on the display. I have changed the pressure transducers and even the transmission charge pump but there's no improvement. Please assist if you have an idea what the cause could be.
Thank you.
  • Posted 6 Nov 2023 02:13
  • By Juma
  • joined 23 May'15 - 29 messages
  • Nairobi, Kenya
Nyakwar Obuolo
Hi friend?
Thanks for for your assistance. Let me work on that then I will get back to you.
Thank you,
John Juma
  • Posted 3 Dec 2023 04:46
  • By Juma
  • Nairobi, Kenya
Nyakwar Obuolo
Juma,
Since you have no codes then all sensors and switches should be good. Check the arm that goes to the switch for your service brake pedal. The switch has a sweep voltage of 4.5 to 2 volts. If it is not reading correctly or loose, can cause the transmission to loose travel. How many hours on the machine. Verify fluid level and color of fluid. When was the filter last changed? If the filter is black, that came from the factory. This post is old, hope you have already repaired. Good Luck.
  • Posted 28 Nov 2023 03:09
  • By Fishmech
  • Virginia, United States
