No steering on a RTW35
Unit operates fine with no codes its just that the steering does not turn on when there is someone in the seat and driving. You need to activate the hydraulic function to get pressure to make the steering work. Its obvious that what ever controls the pump when steering is select it not working. I have no books for this unit and trying to get one.
Thanks
  • Posted 12 Jul 2014 03:37
  • By tomas_s
  • joined 24 Sep'10 - 60 messages
  • Bahamas, Bahamas
when you are sitting on the seat steering do you hear the hydraulic motor running? if so check hydraulic pressure. if pressure ok the pod valve is most likely bad.
if motor is not running it would be easiest to get the dealer to come out and diagnose with laptop. with no codes you could be chasing something as simple as corrupted software values.
  • Posted 12 Jul 2014 12:40
  • Modified 12 Jul 2014 12:42 by poster
  • By stam
Maxlion ESD15M
Hitachi HX64B2
Hawker Powersource, Inc.
