No start
Hello,
Have a cat
Gc15k
At81e00063
Unit spins. No start. No spark. Customer states unit just died. I have no sparks or from coil. Swapped a coil, same complaint: the issue I am having is the back of the distributor for the pickup has a 2 wire plug. No input to it. Just hanging there. What I'm wondering is that the design of this unit or has the plug been snagged and I can't find it? Don't have access to a schematic as this is my only caterpillar in my fleet.
Good battery, fuses, etc. haven't seen a distributor pickup without a power source:
Edit. How are the crank teeth supposed to look?
  • Posted 20 Jun 2024 03:41
  • Modified 20 Jun 2024 03:50 by poster
  • By Hero5
  • joined 17 May'14 - 56 messages
Take care of the customer
The teeth only stick out about 1/8 from the ring but none are smaller or taller they should all be the same size. If that is not the case and the sensor is far away replace the ring and the sensor.
  • Posted 20 Jun 2024 23:08
  • Modified 21 Jun 2024 07:57 by administrator
  • By Scott_
  • joined 16 May'21 - 342 messages
Scott
Some teeth are close. Some are far away because of the wear down the teeth. Haven't put a feeler in there yet but it's consistent around the crank
  • Posted 20 Jun 2024 22:58
  • By Hero5
How far is the sensor from the teeth it should almost touch the teeth.
  • Posted 20 Jun 2024 22:55
  • By Scott_
Scott
Do you have an email?
  • By Hero5
Wish I could send a picture of it. It's definitely wild how knocked down these teeth are
  • Posted 20 Jun 2024 22:38
  • By Hero5
I never seen that but if the crank sensor is not close to the teeth you will not get spark also if you replace the ring with the teeth make sure you you put it back in the same position or it will fire wrong a believe there is a white line on the ring.
  • Posted 20 Jun 2024 22:34
  • By Scott_
Scott
Hello,
Ok that makes more sense now on this distributor. No spark from the coil. The crank teeth on the pulley are horrible, knocked down and not square like they should be
  • Posted 20 Jun 2024 22:14
  • By Hero5
4g64 engine ck time belt is the rotor not trun ing wen craking
  • Posted 20 Jun 2024 16:34
  • By raul_rodriguez
  • joined 27 Feb'20 - 5 messages
Raul
First there is no pick up coil that distributor has a plug connector but there is no wire the distributor is only used to distribute the spark to the plugs as it spins it has no bearing on spark. The front of the engine has the teeth on the side there is a crank sensor as the engine spins it creates and ac analog signals it then is sent to the ecm then the coil is fired to the distributor and to the plugs if you have no spark make sure your power relay is good and look at the crank sensor if all is good it is possible the spectrem ecm is the problem or wiring
  • Posted 20 Jun 2024 12:55
  • By Scott_
September 8-9, 2026 - Barcelona, Spain
November 11-12, 2026 - London, United Kingdom
February 8-10, 2027 - Mumbai, India
Leonardo Quintero Stollwerck Leonardo Quintero Stollwerck
Senior manager sustainability, KION Group
General manager, Autoquip
VP and CEO, Toyota Material Handling Australia
President and chief executive officer, Toyota Material Handling Australia (TMHA)
Still GX10
Still GX10 2000
Poland
EUR950
SMV (Konecranes) 4632CC5
Zhejiang UN Forklift Co., Ltd
